2008 Chevy Impala Electrical
3,000 MILES • 6 CYL • FWD • AUTOMATIC
FPBAUER
The auxilary outlets power stays on when the key is off. This leaves my GPS on.
How can I connect to a power down circuit or change the outlets to power down
Thanks
Jan 19, 2008 at 9:16 AM
MASTERTECHTIM
  • 4,750 POSTS
you will have to physically cut the wires at the back of the plug and switch it to ignition voltage. your local stereo shop will probably do it for you the cheapest. they can probably do it in less than an hour. hope this helps
Jan 19, 2008 at 9:37 AM
