2006 Chevy Impala Cost for a water pump
2006 CHEVROLET IMPALA
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
CJJOHNSON
I was quoted $750 to get my water pump replaced. After reading about the water pump. I am not sure if that is the real problem. My car was not leaking anything. The heat was only working when I stepped on the gas. When I am on the brake then it would blow cold air. Does this sound like a water pump issue and is $750 the normal cost to replace this on my type of car.
Dec 16, 2009 at 4:55 AM
MMPRINCE4000
  • 8,548 POSTS
What engine? 3.4 or 3.8.
The sypmtoms you describe sounds like a pump or possibly a restriction in cooling system.
$750 is a little steep in my opinion.
Does car overheat if idleing?
Dec 17, 2009 at 1:10 AM
