2005 Chevy Impala speed reading
2005 CHEVROLET IMPALA
112,235 MILES • 6 CYL • 2WD • AUTOMATIC
GORGEOUSMAMI6
I have a 2005 chevy impala and sometimes the speedometer will act up. Meaning when that car is off it is still reading 30 or 20 so when I do turn it on when I'm going super slow it saying I'm going 50. Now I can feel how fast I'm going so it not a concern but should I be concerned and get it fix??? N how do I know when to change the brakes cause there starting to make nosie???
Mar 11, 2010 at 12:02 AM
LEGITIMATE007
  • CAR REPAIR CONTRIBUTOR
  • 5,121 POSTS
I think by your speedometer reading 20 or thirty when the car is off, means the vehicle speed sensor is using power from the battery to do this, you will need to correct this at some point. but I dont beleive you should be worried, as far as the brakes, that squeel 9 times out of 10 is the little metal sensor scraping against the rotor, that indicates the pad is low enough for that little piece of attached metal to scrap and signal low pads . its early , I hoped I explained that so you can understand.
Mar 11, 2010 at 7:29 AM
