Stop Leak is not a permanent fix, it is only meant to be a temporary fix. It sounds like it worked fine and the problem is back because the Stop Leak has worn out. Either put more in (not recommended) or have the leak fixed properly.
SPONSORED LINKS
Thursday, January 31st, 2019 AT 6:42 PM
