Leak from transmission cooler Line?
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRACCHUS
Hello - I recently had my transmission replaced but have noticed small oil residue in my driveway. I took it to a different service place - they inspected it and told me that I had a leak around my transmission cooler line. My question is - what damage can occur by not "plugging" this leak? Also, what is the general cost of repair?
Jun 16, 2009 at 1:49 AM
2CARPRO JACK
  • 11,533 POSTS
Depends on if they repair the existing line or replace it.Either way it should be around $100 or less.If you let it get too low,it could damage the trans internally
Jun 16, 2009 at 5:34 AM
BRACCHUS
When you say get too low - you mean the transmission fluid right? Or is there some kind of cooler fluid? Also - when I had the fluid level checked, the technician said that it wasn't low at all
Jun 16, 2009 at 6:30 AM
2CARPRO JACK
  • 11,533 POSTS
Yes I mean trans fluid, that is what runs through the cooler.It will have to leak alot to show it being low on the dipstick
Jun 16, 2009 at 7:30 AM
