Try that first because that is a cheap fix if it works. If it still will not turn, it may be a problem with the key. Keys these days have computer chips in them and if the key was bent or damaged, it may not work. If you have a spare key, try that.
If neither of those things work, you may need a new ignition cylinder. Inside the ignition is a sidebar with springs on it that moves aside and allows the cylinder to turn when the key is inserted. The springs on this can go bad and then there is nothing to do but replace the entire assembly. Hopefully cleaning the ignition out or trying another key will work for you.
Sunday, May 18th, 2008 AT 7:18 PM
