2004 Chevy Impala Wipers
RALPH NAZARIO
  • 2004 CHEVROLET IMPALA
Interior problem
2004 Chevy Impala 6 cyl Two Wheel Drive Automatic 71.000 miles
The driver side Wiper is stuck in the up position Is this a common problem with the Impala?
How do I fix it?
Tuesday, January 12th, 2010 AT 7:18 AM
ERNEST CLARK
  • 1,730 POSTS
It's not necessarily a "common" problem, but it does happen.
Does that wiper work at all? If so, does it just stop half-way up? Or does it not work at all?
If it doesn't work at all, then it's that motor has failed, or the wiring/connector is broken/corroded. If it does work, but stops half-way up, then your wiper mechanism may be jammed by a twig or rock.
If you pop the hood, take a look and move the arm manually while looking for a cause. There'll have to be a reason why it's jammed, you'll just have to find it.
Friday, January 15th, 2010 AT 10:03 PM
