Computer problem
2004 Chevy Impala 6 cyl Front Wheel Drive Automatic
i took off the dash board to fix the heater and now the ignition won't turn at all won't turn to power start nothing any tips to fix the problem
Thursday, February 18th, 2010 AT 6:18 PM
BASSTECH
MEMBER
Don't really know how you went about taking the dash out, but is it possible that brake shift interlock cable that is attached to the ignition switch install incorrectly? You may have to pull the ignition switch out again and see if it turns freely outside of the dash.
