1974 Chevy Impala dash board
JERRYSRIOS
  • 1974 CHEVROLET IMPALA
  • V8
  • 120,000 MILES
The gas gauge, speed meter gauge, the mileage gauge nothing works when I turn on my car so I dont know how fast im going and I dont know how much gas I got and my miles stay at 120,000 and dosnt move, none of the gauges on my dash board work. What can be the problem and how can I fix the problem?
Monday, June 14th, 2010 AT 10:42 PM
FACTORYJACK
  • 4,159 POSTS
I don't know how much information I have available to me for your car. I do know this, your speedometer, and odometer are run off a cable from your trans to the speedometer head. You can check at the trans to see if there is cable damage, run the cable with a drill to see if the speedo will work, and then you would have to remove the cluster and check the cable connection, and also see if the cable spins.
Friday, June 18th, 2010 AT 10:50 PM
