HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Impala
Climate Control
Heater
Not Working
2004 Chevy Impala
STIZZ
MEMBER
2004 CHEVROLET IMPALA
Heater problem
2004 Chevy Impala 6 cyl Two Wheel Drive Automatic
MY HEAT DOESN'T COME ON. MY AC WORKS JUST FINE THE AIR BLOWS JUST FINE BUT NO HEAT
Tuesday, November 11th, 2008 AT 4:51 PM
BLUELIGHTNIN6
MECHANIC
Sounds like your thermostat needs to be replaced.
Are the hoses from the radiator getting hot to touch after driving?
If one is hot and other one isn't, your heater core may be faulty.
Wednesday, November 12th, 2008 AT 1:12 AM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
No Heat Inside And Overheating
In Less Than A Mile The Car Overheats And Has No Heat Inside, I Have No Leaks And My Mechanic Supposedly Replaced The Thermostat, But I...
Asked by
brethoyler
1 IMAGE
2004
CHEVROLET IMPALA
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
2004 Chevy Impala Heater Not Blowing Hot
Have A 2004 Impala Ls 3.8l. The Heater Stopped Blowing Hot Recently. Now Its To The Point It Doesnt Even Blow Warm Air. Also Around The Same...
Asked by
jssmitty
2004
CHEVROLET IMPALA
Heater Blows Cold Air
The Heater Will Blow Cold Air Even When Temp Gauge Is At Halfway Point. As Soon As You Drive The Car It Starts To Heat Up And Work Fine....
Asked by
gambler66
5 IMAGES
2007
CHEVROLET IMPALA
Heater Not Working
Heater Not Working When Car Is Idling, When You Drive Heat Works
Asked by
SEFL
1 IMAGE
2006
CHEVROLET IMPALA
Passenger Side Heater Blows Only Cold Air
Drivers Side Heater Works, Passenger Side Only Blows Cold Air. No Clicking Noises.
Asked by
Marcus E. Brannon
3 IMAGES
2009
CHEVROLET IMPALA
VIEW MORE
Heater Not Working
Blend Door Actuator Replacement
