2003 Chevy Impala Service Engine Soon light
VOLPI
  • 2003 CHEVROLET IMPALA
Electrical problem
2003 Chevy Impala V6 18000 miles
After replacing the BCM, the Service Engine Soon light remains on. This light was not on before the BCM was replaced. When the trunk is unlatched and the lid bounces gently, the light goes on and off. We tried changing the trunk switch with no effect. The Service Engine Soon light remains on.
Also, after the BCM replacement, when the headlights come on, the clock radio display disappears. When the headlights are off, the display appears again. This was also not present before the BCM was replaced.
Any help would be appreciated!
Volpi
Tuesday, December 4th, 2007 AT 12:43 PM
DENNYP
  • 1,824 POSTS
Did you have the bcm programmed after you installed it? Is it a new or used part?
Sunday, December 16th, 2007 AT 1:49 PM
VOLPI
Yes the BCM was programmed after it was put in. The BCM was a new part from the dealership.
Do you have an idea what it could be?
Thanks!
Wednesday, December 19th, 2007 AT 2:37 AM
