Engine Performance problem
2003 Chevy Impala 6 cyl Two Wheel Drive Automatic
what can cause the check engine light to stay on. code p0171 (to lean)... i changed the fuel filter, and the oxygen sensor, and check the vacuum lines for leaks (none).. fuel pump is okay. what else can be done? where is the egr located? how to clean it or replace it?
May 14, 2008 at 12:39 PM
