2003 Chevy Impala antifreeze leaks
95,000 MILES • 6 CYL • FWD • AUTOMATIC
MR LOCKWOOD
my water pump was leaking so i had it replaced with a new thermostat. it was fine for a while then another leak appeared .so i had it pressure tested again and they said the timing gasket is badis that true or not can you tell what else it could be.
Dec 9, 2009 at 7:46 AM
MMPRINCE4000
  • 8,548 POSTS
Is it the 3.8 engine?
Dec 11, 2009 at 1:30 AM
MR LOCKWOOD
to answer your question.it's a 3.4 engine
Dec 14, 2009 at 2:29 PM
MMPRINCE4000
  • 8,548 POSTS
Not sure what they mean timing gasket. The 3.4 uses a cartridge pump and is sealed with an O'ring.
Timing chain is enclosed and coolant should not be leaking anywhere near it.
Have them give you the specific part name.
In any case they should have fixed it the first time, I would tell them to fix it on their dime.
Dec 14, 2009 at 10:25 PM
