2003 Chevy Impala antifreeze leaking & fluctuating engi
83,000 MILES • 6 CYL • FWD • AUTOMATIC
DEGATELY
I suspect that I either have a radiator leak or hose leak. Coolant has been leaking for the last few weeks. I can smell the antifreeze. The engine temp has also been fluctuating. I had the radiator flushed and new coolant put in and this helped for about 2 weeks but now it's leaking again. What could be the other possibilities?
Assuming that the radiator had to be replaced, what is the usual cost?
Degately
Jul 15, 2008 at 2:18 PM
  • 31,937 POSTS
Hi there,
could be any number of cooling system components, best you have a pressure test done on the cooling system, this will help to locate any external leaks, get this done first.
Mark (mhpautos)
Jul 15, 2008 at 2:21 PM
