2003 Chevy Impala 2003 impala stering & water pump prob
2003 CHEVROLET IMPALA
189,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEBROWN1986
i was laving store and went to turn and lot power steering got out to check and my water pump was leaking out of weeping hole.drove home and steering came back makes a noise time to time.but steering is still there hasnt went out but pump is still leaking antfreeze.ty
Nov 4, 2010 at 5:58 AM
RENAUDTN
  • 636 POSTS
If your water pump is leaking, replace it asap. A refurbished one will cost you around $15 at an autopart store; a little more for a new one. If you have it done at a shop, it’s gonna be around one hour of labor + parts, so probably around $200-250 more or less depending on where you go.
As far as your steering problem, make sure you’re not running low on power steering fluid, and check for leaks if you are. If level is alright check your power steering pump and pulley.
Nov 5, 2010 at 2:27 AM
