2005 Chevy Impala water pump
JLMATTHEWS
  • 2005 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 54,000 MILES
I recently changed the water pump on my impala as it was starting to leak, and filled the radiator and filled the reservoir halfway, and ever since I did this the temp guage has been rapidly fluctuating between 140 and 240, although never into the red zone. I have also noticed that since the change I have lost all heat, and only get very cold air now, where with the old pump I had the best heat ever, what could be the problem now?
Friday, November 27th, 2009 AT 5:26 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like you have an air pocket. The heater core is the first to lose when the level drops. Try bleeding the system a few times to try to get it out. Recheck level when cold.
Friday, November 27th, 2009 AT 6:41 PM
