2002 Chevy Impala fuel pressure
2002 CHEVROLET IMPALA
86,000 MILES • 6 CYL • FWD • AUTOMATIC
THOMAS SHERO
At times when pushing down on the gas pedal the car will act like its out of gas. after 300' feet it will take off like normal. I checked the press with a guage and found that wit key on, not running the press 46 and goes up to 51 slow and stops. Ar idle it reads 44. After off for 1 hr. it goes down to 7. Is it a bad regulator or fuel pump ???? Its a 3.8 v6 eng.
Thanks
May 16, 2009 at 4:14 AM
JDL
  • 16,098 POSTS
Hello, my info shows key on engine off fuel pressure, 53-59. Idle-43-56. What does the pressure gage do if you quickly open and close the throttle? If the pressure drops more than 2 psi, there is a supply side problem, filter--pump--clogged fuel line??
You might pull the vac line off the regulator,see if there is any gas in the line. With the vac line off and engine idling, I believe the pressure should go up a little??
I believe the pump manufacturer will give you a bleed-off spec. That bleed-off spec sounds too fast to me?
May 16, 2009 at 4:48 AM
