2002 Chevy Impala GAS SMELL
LRAMIREZ1120
Smells problem
2002 Chevy Impala Automatic 135000 miles
When I start my car up in the morning it smells like gas and get even worse if I turn the heater or air on.
Is it my fuel pressure regulator if so when replacing the fuel pressure regulator do you also have to replace the gasket.
Feb 16, 2009 at 1:36 AM
RHALL77
  • 3,361 POSTS
most likely it is your regulator. if your not sure how to replace it purchase a repair manual. you will have to remove the upper intake. unless you know what your doing, you dont have to
Feb 16, 2009 at 8:05 AM
