Maybe 2 separete issues.
HAving said that, If you have a long crank in the morning it will be adding fuel that can cause the raw fuel smell.
The dead ignition is a security problem, possible ignition switch.
I would start off by checking for what codes are stored in the pcm and bcm.
SPONSORED LINKS
Wednesday, August 5th, 2009 AT 6:07 AM
