2002 Chevy Impala car cranks but won't start
CARTERJL
  • 2002 CHEVROLET IMPALA
  • V8
  • FWD
  • 13,500 MILES
I drove the car home last night parked it in garage. My wife went out to start it this morning. Cranked but wouldn't start. Put some gas in thinking it was out of gas still won't start. Any ideas.
Monday, February 8th, 2010 AT 10:21 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Have a helper crank the vehicle, while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
To check for spark at the plugs, you can pull a spark plug boot, stick a known good plug in the boot or use a spark tester, the autostore sells them, you plug into the boot and ground to metal part of engine, watch for spark as the engine is cranked.
Saturday, March 6th, 2021 AT 1:32 PM
Related Engine Not Running Content
