2001 Chevy Impala Rear turn signal
2001 CHEVROLET IMPALA
SCHMITTY
2001 Chevy Impala 6 cyl Automatic 99000 miles
Left rear turn signal bulb needs replacing. However, how does this assembly get taken off? You take out the interior wing nuts, pull back trunk liner, undo those wingnuts, and then what? Unfortunately for me, 1st chevy and am not familiar with what should be a simple fix...cannot believe I have to ask. Please help.It is snowing here and I must get this tended to asap.
Jan 19, 2009 at 10:52 AM
  • 110,244 POSTS
Hi:
If you remove all of the wing nuts, just push outward on the studs and it should push out.
Let me know if this works for you.
Jan 20, 2009 at 12:00 PM
SCHMITTY
[quote:55a7045386="Jacobandnickolas"]Hi:
Joe[/quote:55a7045386]
Thanks Joe-it worked just fine. Appreciated your assistance. Wanted to make sure before I made the attempt to push out , all would be okay. It is freezing cold outside-no garage-did not want any surprises with the taillight assembly. Thanks again!
Jan 25, 2009 at 12:11 PM
