2001 Chevy Impala 2001 Imapala: A/C problems and Engine noi
MSANCHEZ07
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • AWD
  • 110,000 MILES
My car is blowing out hot air when its hot outside and cool and when its cool outside and only work on setting 3 and up. Also there is a "boom boom" noise when the car is turned on and while driving it gets louder when I press on the gas. And the blinkers do not work sometimes.
Thursday, September 4th, 2008 AT 10:22 AM
RHALL77
  • 3,361 POSTS
Have the freon pressure check. Sounds like a leak. The blower is usually a resistor that is going bad. The blinkers may be a turn signal switch acting up. Can you better describe the noise your getting
Thursday, September 4th, 2008 AT 6:06 PM
MSANCHEZ07
My 2001 Impala is making rattle-like noise its coming from underneath the car.
Thursday, September 4th, 2008 AT 7:18 PM
RHALL77
  • 3,361 POSTS
When idleing or driving?
Friday, September 5th, 2008 AT 9:51 AM
MSANCHEZ07
This noise happens when I am stopped and when Im driving it sounds louder when I step on the gas. I recently got freon put into my car and dye because there is a leak somewhere in the car that caused the A/C not to function properly, but ever since, when I am driving the fuel gauge reader on my car tells me that I am empty when I am stopped, but when I step on the gas the needle slowly moves up and I know that I have less than 1/2 tank left but the reader tells me other wise, and it went up to the "Full" level at some point then went back down when I started slowing down so I dont really know exactly around how much gas I have left.
Sunday, September 7th, 2008 AT 6:22 PM
RHALL77
  • 3,361 POSTS
Sounds like you need a fuel level sensor, and the freon leak checked. You also should tske it somewhere to have the noise inspeced.
Monday, September 8th, 2008 AT 12:57 PM
