2000 Chevrolet Impala Bogs at Highway Speed
NEWSMITH
My Impala has 111,000 miles on it. About three months ago I noticed that when accelerating the car, it seemed to "bang" into gear. I was told the transmission was slipping and to add transmission fluid to it. I was also told that the engine could be dirty so I had the cars engine "moto vaced" (thinking that the fuel injectors were dirty) and topped off the transmission fluid. This only slightly improved the cars performance. Lately the car has started to "bog" when reaching 60 to 65 mph, feeling as though it's "choking" for air. The air filter is clean. I also noticed that the fuel mileage this tank went from 379 miles per tank full to 290 mile per tank full. It doesn't matter what type of weather is outside or if the car is warmed up or not, it does it anytime.
Is this a camshaft sensor issue or another type of censor issue? I'd like to visit that before putting in a new transmission or some other major repair.
Mar 8, 2007 at 12:06 AM
MERLIN2021
  • 17,250 POSTS
that's a good one...!!! Ok i'm better now! The 2 most important sensors in your car for mileage and "Bogging" are the Mass Airflow Sensor and the Oxygen sensors. It is recommended to change the oxy sensors at 100,000 mi. even if they aren't lighting the MIL! They do get sluggish! Oh and don't forget the tune up...
Mar 11, 2007 at 2:29 PM
NEWSMITH
I will try replacing both of these sensors. I appreciate your advice!
Oh, and as for the motor vac, I am pretty convinced that was a complete sham, so no wonder you laughed at that...
Do tell, what is up with the clown pic?? That is pretty funny!
Mar 12, 2007 at 7:56 AM
Suggested Repair
Before replacing the transmission, inspect and replace the mass airflow sensor and oxygen sensors, which are due around 100,000 miles even without a warning light, and perform a tune-up.
Conversation Summary
A 2000 Chevrolet Impala with 111,000 miles bangs into gear under acceleration and later bogs or feels starved for air around 60-65 mph, with fuel economy dropping from about 379 to 290 miles per tank. Adding transmission fluid and an engine cleaning only slightly helped, and the air filter is clean. The expert identified the mass airflow and oxygen sensors as the main items affecting mileage and bogging, recommended replacing the oxygen sensors around 100,000 miles even without a warning light, and advised a tune-up. The owner planned to replace both sensors.
