2000 Chevy Impala windsheild wipers
98,000 MILES • 6 CYL • FWD • AUTOMATIC
BJSIMS55
This winter i turend my windsheild wipers on when they were frozen to the windsheild. Naturally, the wipers should go down below the window when they are shut off. Now, when i shut them off they go all the way to the up position and stop. It seems like they are confused and dont know where the shut off position is. Is this a problem where i will need a new motor or is the motor just out of a-line?
Feb 13, 2008 at 8:10 AM
DENNYP
  • 1,824 POSTS
Wipers Blades Do Not Park
Step
Action
Value(s)
Did you review the system operation and perform the necessary inspections?
Go to Step 2
Go to Symptoms
2
Turn the ignition switch to RUN.
Turn the wiper switch to OFF.
Disconnect the wiper/washer switch connector.
Do the wipers park?
Go to Step 3
Go to Step 4
3
Replace the wiper/washer switch. Refer to Multifunction Turn Signal Lever Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Did you complete the replacement?
Go to Step 9
4
Measure the voltage from the wiper/washer switch connector (vehicle side), terminal B6, to ground.
Does the voltage measure greater than the specified value?
1.0 V
Go to Step 6
Go to Step 5
5
Replace the wiper motor cover. Refer to Wiper Motor Cover Replacement .
Go to Step 9
6
Reconnect the wiper/washer switch connector.
Disconnect the wiper motor connector.
Measure the voltage from the wiper motor connector, terminal D, to ground.
1.0 V
Go to Step 8
Go to Step 7
7
Go to Step 9
8
Repair the short to voltage in CKT 113. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 9
9
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Apr 3, 2008 at 2:22 PM
