Ron,
I hope you have already found the cause of the stalling problem by now. I suffered with mine for six months before I finally discovered it was caused by the crankshaft position sensor. I had it replaced 3 years ago and have not had another problem with the car.
The sensor has a magnetized area that, over time, attracts a build-up of metallic particles. I am not certain, but I believe if the built-up particles was removed, the problem would disappear with the particles.
Anyway, if you still have the problem, try checking out the crankshaft position sensor.
TakeChargeSarge
Jul 17, 2009 at 3:15 AM
