2000 Chevy Impala horn stays on
2000 CHEVROLET IMPALA
ORANGE72CHEVELLE
2000 Chevy Impala
if the horn relay is in the horn stays on, bought a hayns manual and it was wortless it did not have any horn wirring diagrams what would cause this i can't figgure it out i just bougt the car and it was not working
Oct 25, 2009 at 7:10 AM
JDL
  • 16,098 POSTS
welcome to the forum. with horn relay removed, check terminal E6 for ground, use led testlite connected to battery voltage, touch terminal, if lite comes on, the circuit is grounded. It shouldn't ground unless you honk the horn. Possibilities, the wiring circuit in the steering column/ horn button is shorted to ground. There is another possibility, if you have an entry type theft system, the bcm can ground that circuit.
Oct 25, 2009 at 8:28 AM
