2000 Chevy Impala Driver Door Power Window
115,000 MILES • 6 CYL • FWD • AUTOMATIC
MELVNMSS
Last night when I got home I pushed the button to put my window up. It got almost all the way up but then fell. Never had a problem before. I took the door panel off thinking it just fell of the track but have no idea what I'm looking at. I am trying to find some picture step by step instructions how to replace the motor if that is what needs to be done so I can have someone help me instead of paying an arm and leg at a mechanic. My funding is low so I'm thinking of buying some small c-clamps and putting them on the vertical post the window moves up and down on the hold it up until I have funds to fix it. Please help.
Apr 27, 2009 at 4:18 AM
RHALL77
  • 3,361 POSTS
sounds like you need a regulator. can you see if the regulator is going up and down when you hold the window up? maybe the window bracket came loose and its not holding to the regulator.
Apr 27, 2009 at 7:46 AM
