1994 Chevy Impala car shuts off
BOBBETT26
  • 1994 CHEVROLET IMPALA
  • V8
  • 132,000 MILES
My impala ss just started shutting off the other day when I got to the stop sign it act as if it was out of gas it was putting and then it would just shut off was hard to start I let it cool down and about a hour later it crank up fine but when it would cut off the door locks would start to engage as if I were pushing the button which was not happing a guy told me that my catalatic converters could be the reason please help
Friday, April 2nd, 2010 AT 7:49 AM
TWOSTEPPER
  • 42 POSTS
How long since a tune-up? Make sure the battery has a full charge and the connections are good. Check charging system. Use a gage and check fuel pressure. Idle air problem, clean throttle-body. Any trouble codes?
Friday, April 2nd, 2010 AT 8:27 AM
BOBBETT26
I change the spark plugs every year and the oil every 5 to 6k I only drive the car at the most 10,000 a year the battery is a little old it has a new fuel pump but I didn't change the fuel filter throttle body I took it off and cleaned it pretty good new gaskets and all I didn't change the trans fluid or the tranny filter this year yet the only problem that I see is I have only one elect fan workingthe motor burned out on the other fan not sure where to go from here can't give up
Friday, April 2nd, 2010 AT 9:48 AM
Related Engine Stall While Driving Content
