2006 Chevy HHR Head Gasket
2006 CHEVROLET HHR
62,000 MILES • 4 CYL • FWD • AUTOMATIC
SMOLLOY
I went to change my spark plugs and noticed a small amount of oil had leaked down into the number 2 plug area right from where the block and the head are connected. It appears to be my head gasket is leaking oil slightly. It appears I can readily get to all the bolts to remove the head, should I attempt this myself (do not have the funds for dealer repairs) and can you tell me what the bolts should be torqued back down to? Anything special I should know about changing this head gasket? I can do minor repairs, but never attempted a head gasket before. I can send a pic if needed.
Thank you so much for your help -
Steve
May 29, 2009 at 8:09 AM
DOCFIXIT
  • 18,828 POSTS
O.K.
what is leaking is not a head gasket it's the valve cover gasket. yes you can do remove any wiring , cables in way then unbolt remove cover .
May 29, 2009 at 8:33 AM
SMOLLOY
Oh my..how stupid am I. Yes, the valve cover gasket! Thank you thank you! Sending a donation - thanks for your help!
May 29, 2009 at 8:37 AM
DOCFIXIT
  • 18,828 POSTS
Thanks smolloy
Doc
May 30, 2009 at 3:12 AM
