2002 Chevy Express starter
2002 CHEVROLET EXPRESS
135,000 MILES • V8 • 2WD • AUTOMATIC
JIMRILEY1
starter comes on after van is already running
I have changed the relay and starter and it still happens
Dec 23, 2008 at 8:49 AM
JDL
  • 16,098 POSTS
After the vehicle is started, pull the relay, you don't need it for driving, just starting.
If the problem goes away, check the circuits before the relay. If the starter still does it, check the circuits after the relay.
You may need to see what the starter pinion gear is doing, after the key is released from the crank position.
Dec 23, 2008 at 10:38 AM
