Does any one have any info on how to change starter on my 2000 Chevy Express V8
Thank you
Dec 5, 2008 at 10:16 AM
✓Experienced Mechanic
Hi:
The starter is the same as any. First disconnect the battery. Next, locate the starter near where the transmission and engine join. Next, unbolt the wiring. Finally, remove the two bolts that hold the starter. After the bolts are removed, the starter can be removed too. Just reverse the order to replace.
