1996 Chevy Express spark plug change
165,000 MILES • V8 • 2WD • AUTOMATIC
O381697
Been a while since I changed spark plugs and wires in a car. How do I access the spark plugs in an Express Conversion van? Through the interior engine cover? If so, how is that removed? I can't see any clips or other fasteners. Thanks
Mar 30, 2008 at 12:30 PM
BMRFIXIT
  • 19,053 POSTS
it comes out in two pieces
remove the trim under the radio and by the ash tray
you ll. find the nuts
and the bottom you have two more
and remove the upper part then the 2nd cover has like a belt just pull it out
replace the cap and rotor too
some plugs you can access from over the tire
Mar 30, 2008 at 12:56 PM
ACTION JACKSON1960
  • 5 POSTS
my van i took the front wheels off and the were simple to change .you have to pull dog house also for wire,s cap and rotor ........easy as pie .now this power steering thing is another animal dang(@@)
Dec 6, 2008 at 10:18 AM
