1986 Chevy El Camino 6 cyl Two Wheel Drive Automatic
Have oil leak or oil run. Comes down the back side of engine. Replaced the oil sencor still runs out when engine runs.
Monday, July 13th, 2009 AT 12:55 PM
LOUT5369
MECHANIC
I guess its a V6, sounds like the distributor is leaking, remove the distributor and replace the gasket/o-ring, be careful make sure you line the distributor up correctly or the timing will be off and you could damage the oil pump
