1982 Chevy El Camino MY CAR CRANKS OVER ,BUT IT WONT START,
1982 CHEVROLET EL CAMINO
156,058 MILES • V8 • 2WD • AUTOMATIC
GONEBINO1
THE CAR CRANKS ,IT JUST WONT START ,THERE IS GAS FLOWING IN THE CARB.
May 24, 2009 at 5:10 PM
Try checking for spark and then comeback with some results
May 24, 2009 at 9:48 PM
GONEBINO1
I REPLACE MY COIL,BUT THERE'S STILL NO SPARK.WHEN CRANKING OVER ENGINE
May 25, 2009 at 3:29 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
May 25, 2009 at 8:41 AM
LOUT5369
  • 217 POSTS
Were you driving it and it stalled and wouldn't restart,if so replace ign module,if you shut it off and it wouldn't restart,replace distributor. the module is under the cap,remove cap,remove rotor and its right there with 2 7/32 screws holdin it down.
Jul 24, 2009 at 5:00 AM
