Also, the 4 speed will not go into reverse.
Any ideas for either issue?
For no reverse, inspect the shifter bushings on the shift arms at the side of the transmission. To remove the stuck ignition key, the steering wheel must come off so the tumbler can be removed; on a telescoping Corvette wheel this is difficult, so a shop with the proper tools is recommended.
The owner of a 1974 Chevrolet Corvette that sat unused for 25 years says the ignition turns to start but will not turn back far enough to release the key, and the 4-speed will not go into reverse. The expert says missing reverse is likely a bad shifter bushing on the transmission shift arms, and that removing the ignition tumbler requires pulling the steering wheel, which is difficult on telescoping wheels and may be best left to a shop.
