1991 Chevrolet Corvette White Smoke
BERNARDV777
I have a 1991 corvette convertable with 96000 miles on her I went to start it today and thick white smoke came out of the exhaust and anti freeze was dripping out of the tail pipes
Ichecked the oil and there sems to be anti freeze on the stick
How can I repair this and approx. how much will it cost
thanx,
bernardv777[/b]
Apr 16, 2006 at 12:02 PM
LOSONE
  • 1,616 POSTS
Major bucks. You have blown either a head gasket, have a cracked head or something worse. The first step is to pull the heads and see where the coolant is leaking. i suspect a cracked head on the passenger side. Thats the one that cracks most of all. Good Luck Let me know BUT DON"T DRIVE IT and drain all your engine liquids.!!
Apr 16, 2006 at 1:01 PM
BERNARDV777
thank you I suspected that
have a great holiday!
bernard
Apr 17, 2006 at 1:49 AM
Suggested Repair
Do not drive the car. Drain the engine fluids, then pull the cylinder heads to find where coolant is entering the engine. Likely causes are a blown head gasket, a cracked head (often the passenger side), or worse internal damage, and the repair will be expensive.
Conversation Summary
The owner of a 1991 Chevrolet Corvette convertible with 96,000 miles reported thick white exhaust smoke, antifreeze dripping from the tailpipes, and antifreeze on the oil dipstick. The expert said this indicates a blown head gasket, cracked head, or worse, and advised not driving, draining all engine fluids, and pulling the heads to locate the coolant leak, suspecting a cracked passenger-side head. The owner agreed with that assessment.
