1995 When cold, runs very rough - once warm, runs OK
1995 CHEVROLET CORVETTE
120,000 MILES • V8 • 2WD • AUTOMATIC
LBA0
I have replace 2 oxygen sensors and fuel pump & filter.
I have heard that on the 1995, there is a third oxygen sensor, and this might be the problem?
Aug 17, 2008 at 8:00 PM
BLACKOP555
  • 10,386 POSTS
ill tell you one thing, an o2 sensor will not cause a vehicle to act up when cold, as the computer is in closed loop, and does not take information from the o2 sensors. instead on a cold engine codes are taken from the ECT or ETS. check that first, compare its resistance to that of the IAT sensor.
Aug 17, 2008 at 10:21 PM
