1995 Chevy Corvette runs hot in traffic with ac on
119,000 MILES • V8 • 2WD • MANUAL
FEEN
while i am in traffic my water temp climbs to 240 wth a/c on, i turn off everything get out of traffic drive and temp goes back down to normal i have checked thermostat ,replaced coolant, bled thermo housing, both fans are running with ac on it does not run hot in traffic with a/c off what am i missing. i do have the edelbrock intake with a chip but the computer has been reset for them. the problem started two nights ago i was in bumper to bumper traffic i looked down and temp was 257
Jul 27, 2009 at 10:41 AM
LOUT5369
  • 217 POSTS
Is the A/C blowing cold?Sounds like the A/C condensor may be partially clogged,causing the condensor to get hotter than normal and the fans are pulling the overheated air from the condensor into the radiator,have the A/C performance checked,check for debris between condensor and radiator.let me know what you find.
Jul 29, 2009 at 11:08 PM
FEEN
yes a/c does blow cold lately it's getting around 221 to 224 is this to hot? how hot should it get i did take compressed air and blew out condens. and rad fins alot of dust and dirt came out other than it getting hot car runs terrific
Aug 3, 2009 at 1:53 PM
LOUT5369
  • 217 POSTS
Actually the fans won't kick on until 235-240,if A/C is on ,fans come on low speed,when temp goes up fans will go on high speed,221-224 is hot by my standards,but not by GMs standards.What condition is the radiator in? Is it OEM? Make sure you have good circulation.
Aug 4, 2009 at 4:54 AM
FEEN
rad is in great shape its oem circulates good i didnt know about a low and high speed how can i check to see if high speed is working
Aug 5, 2009 at 11:21 AM
