1993 Chevy Corvette won't start when warm
AUDIE10
  • 1993 CHEVROLET CORVETTE
  • V8
  • 140,000 MILES
Car will start fine when cold. After it warms up (about 5-10 minutes of driving) it will act as though it is out of time. It spins over good but backfires, and will not start. If I leave it for 3-4 hours to cool off, it will start fine. Someone told me the timing chain was stacking on the gears throwing it out of time, until it cooled down. Someone else told me it could be a sensor. This happens about 6 months ago and hasn't done it again until last week. If there is a sensor problem, what sensor is it and where is it located.
Friday, January 29th, 2010 AT 4:06 PM
Hi AUDIE10, Welcome to 2carpros and TY for the donation
Next time it refuses to start when warmed don't wait try to catch it if its fuel or spark related issue do below
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Saturday, January 30th, 2010 AT 5:36 AM
AUDIE10
I don't think you read my question close enough. It seems to be out of time when warm, spinning and backfiring over and over but will not crank. I asked where the sensor was that might give me this effect. Or was the timing chain stacking on the gear then when cooled slip back in place. Your response was a form response I had already read on this sight. Before I spend $1,000 having my chain and gear replaced I would like to replace the sensor to see if that might be my problem.
Saturday, January 30th, 2010 AT 5:54 AM
I don't think you read my question close enough. I read all the question 3X before I answer paid or not-
This will never happen if the timing slipped she won't start it'll probably backfires due to the valve timing being off-When you perform what I gave you it might lead you to a problem with fuel or spark causing it not to start-There's sensors involved in the ignition system, you need to do it
Saturday, January 30th, 2010 AT 6:04 AM
