1975 Chevy Corvette Hard Brakes
1975 CHEVROLET CORVETTE
65,000 MILES • V8 • 2WD • AUTOMATIC
JERRY4914
1975 corvette 4 w/disc. brakes are very very hard, new booster checks good- 20 in. vacum, new master cylinder checks good,new pads,calipers. rotors ` it definetely is not the booster! all air bleed out. any suggestions as i am stumped. Jerry
Dec 10, 2007 at 10:23 AM
  • 31,937 POSTS
Hi there,
I would re check the booster. Turn off engine and pump brakes to evacuate all vacuum. Hold pressure on pedal and start up engine, If booster is working, Pedal will suck down a little. check that booster check valve is working and the booster is getting full vacuum. Check if applicable pedal free play adjustment try this first
Mark (mhpautos)
Dec 10, 2007 at 7:06 PM
