1968 Chevy Corvette will not idle
DMOYE
  • 1968 CHEVROLET CORVETTE
Engine Performance problem
1968 Chevy Corvette V8
my chevy 327 in my boat has suddenly stopped idling well. It won't run at less than 2000 rpm. This just happened. It was running fine and suddenly started this on my last outing. It runs fine at 3000 rpm. It seems to have no power at 2000 or less rpm as well. It has a pertronix ignition and edelbrock 750 cfm carb.
Tuesday, August 24th, 2010 AT 6:45 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check to see if carb is bleeding into venturis at idle if yes then float and seat not shuting off gas ie. Flooding
Let me know
Thanks for donate
Tuesday, August 24th, 2010 AT 11:23 AM
DMOYE
I did take the flame arrestor off while running and noticed alot of gas running through the carb at idle. Bet that's it. Guess it could be a stuck float? Any chance i'll need a new shut off valve?
Thnx
Tuesday, August 24th, 2010 AT 2:22 PM
DOCFIXIT
  • 18,828 POSTS
Edelbrock carb easy rebuild get number and get a kit. Don't want potential fire on a boat
Tuesday, August 24th, 2010 AT 3:46 PM
