1986 Chevy Corvette car
1986 CHEVROLET CORVETTE
80,000 MILES • V8 • 2WD • AUTOMATIC
EDDIE LEWIS
car cranks and starts then dies .fuel pressure 40 lb have put vats bypass made no different. have ingaged pump seperately,made no different.
Oct 11, 2010 at 5:01 PM
have ingaged pump seperately,made no different. I assumed you power the fuel pump from the battery and it continues to start and die, if this the case-check if the injectors are pulsing-
Starts and then stalls sounds more like a fuel problem-
Clean out the idle air control valve and EGR and PCV valves and see what happens-let me know
Oct 11, 2010 at 7:22 PM
