First ill let you know that it is a 4 speed 327 with a mild hydraulic cam freshly rebuilt approx 2 thousand miles ago, hei dist, and original rochester Qjet that was cleaned and has fresh gaskets. No power steering or brakes, it is a base model. I rebuilt the engine prior to deploying overseas and ran good. Upon my return I tried to start it up only to find that my gas tank was full of water. So after draining it, rebuilding carb and flushing lines it was running good. A week later im driving down the road and every time id come up to a stop sign and throw it in netral it would die unless I feathered the gas. Eventually running on its own. It does great under power and ive checked all vacuum lines and gaskets for leaks. Ive also adjusted idle mixture screws, played with the timing, and adjusted the throttle screw. Its sitting around 700, a little jumpy but im assuming its because of the cam. Any insight would be appreciated
SPONSORED LINKS
Wednesday, May 1st, 2013 AT 8:13 PM
