for the last month and a half my temperature guage has been going past the 3/4 mark. Had a pressure test done and was told there was not problem. The temperature gauge finally went all of the way over so I turned off the engine and let it sit for a while and it seemed fine. Finally had the thermostate replaced because I was told it was sticking. The system has been flushed and checked again and yesterday the guage went all of the way over and I had to turn the engine off again. After it cooled I drive it and it seemed fine. What would cause the termperature gauge show the car was about to overheat and then it is fine?
Thank you
