Dome light stays on
CHEVROLET CORSICA
ANOKA114
I have a 1994 Corsica with 124,00 miles on it. The dome light stays on all the time and I suspect it is one of the door switches. How do I find the front door switches and how do I remove the rear door switches to test them? Thanks!!
May 20, 2007 at 3:39 AM
GARFIELD
  • 197 POSTS
You should be able to remove the switch then just disconnect the wire, when you find the bad switch the light will go out. You will most likely have to remove the interior panels to get at the back switch.
May 20, 2007 at 6:44 AM
