1996 Chevy Corsica Dome Light
1996 CHEVROLET CORSICA
170,000 MILES • 6 CYL • FWD • AUTOMATIC
CHLOEZOE
I can not get the dome light to go off. One day i unlocked the drivers door with the key and since then the dome lights and floor lights will not go off.
Oct 11, 2009 at 11:05 AM
BIG_JAY
  • 121 POSTS
[quote:b098584a1a="chloezoe"]Electrical problem
1996 Chevy Corsica 6 cyl Front Wheel Drive Automatic 170000 miles
I can not get the dome light to go off. One day i unlocked the drivers door with the key and since then the dome lights and floor lights will not go off.[/quote:b098584a1a]
It is most likley a door switch. If it has the little button in the door jam push it and see if it goes out. Also try rotateing your dimmer switch to make sure it is not all the way up. Usualy it is the door you use the most. If th button is in the locking mechinism in the door latch itself then u need to go get some wd-40 or I like PB Blaster and spray it all over the latch part of the door and open it and slam it about 10 times.
Oct 11, 2009 at 11:34 AM
CHLOEZOE
the answer did not help at all. No button in the door jam the dial is not in the up position and the wd 40 trick didnt work
Oct 11, 2009 at 12:10 PM
BIG_JAY
  • 121 POSTS
It may be a diff door. I will try n look up a diagram tomorrow. Is there a light on the dash letting you know a door is open? If u open a door does it light up then?
Oct 11, 2009 at 1:24 PM
CHLOEZOE
no warning light on the dashboard
Oct 12, 2009 at 10:49 AM
