1996 Chevy Corsica cranks but won't start
KEVINKELL
  • 1996 CHEVROLET CORSICA
  • 4 CYL
  • 150,000 MILES
The car cranks and won't start. I sprayed fuel into the throttle body, nothing happened, I checked for spark and it has got good spark. Fuel pump turns on. The battery is good and clean. All fuses are good. I don't suspect the timing chain because the car ran fine, then it was parked then all of a sudden wouldn't start. Please help me out and what could the problem be?
Wednesday, March 19th, 2008 AT 2:09 AM
The car cranks and won't start. I sprayed fuel into the throttle body, nothing happened, I checked for spark and it has got good spark-
Priming it won't make it kick-good spark, timing chain intact-fuel pressure unknown-but should fire up when primed-
Check the engine's compression and report back
Wednesday, March 19th, 2008 AT 5:03 AM
LEGITIMATE007
  • 5,121 POSTS
Getting fuel? Check fuel pressure regulator
Thursday, March 20th, 2008 AT 11:51 AM
KEVINKELL
I checked the compression on the cylinders and it pulled 90 psi. What does that mean?
Saturday, March 22nd, 2008 AT 6:57 PM
MASTERTECHTIM
  • 4,750 POSTS
Are they all 90? That is real low. Did you check spark on all 4 cylinders?
Saturday, March 22nd, 2008 AT 7:07 PM
