1995 Chevy Corsica Orfice Tube Location
1995 CHEVROLET CORSICA
MIZIKE
Air Conditioning problem
1995 Chevy Corsica 4 cyl Automatic 130000 miles
AC system not cooling, compressor kicks on, was told that it is a good possibility that the orfice tube is clogged. But can not find the thing. Could someone tell me precisely where the Orfice tube is located on my car? Thank you
Jul 18, 2010 at 3:17 PM
HMAC300
  • 48,601 POSTS
the orfice tupb ei sright in front of the evaporator on the small lline. Bu tdon't mess with it as it has to be properly checked to make sure that is the problem. if it is your desecant bag in the accumaltor has broken to clog it and that will need to be replaced as well. it will also need to be properly evacuated and recharged...
Jul 24, 2010 at 11:17 AM
