1995 Chevy Corsica Engine will not start
PALOS
  • 1995 CHEVROLET CORSICA
  • 4 CYL
  • FWD
  • 200,000 MILES
Ok here is the problem I was May car stalled out on freeway going about 60MPH. I've hanged out the Fuel Fiilter, Changed the Fuel Pump, Checked to make sure the spark plugs are firing, and checked to make sure there is gas.. The car cranks but will not turn over.I'm running out of options Please Help
Thursday, June 24th, 2010 AT 9:48 AM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Thursday, June 24th, 2010 AT 5:04 PM
