Electrical problem
1994 Chevy Corsica 4 cyl Two Wheel Drive Automatic
1994 Chevrolet Corsica; Why do the turn singles flash at abnormal rate and a couple times have stopped? And How do I repair?
Tuesday, September 7th, 2010 AT 10:32 AM
SATURNTECH9
MECHANIC
So does your turn signal flash faster then it usually does?If so the first thing I would check is that all your turn signal bulb's work. If the all do then you could just have a bad turn signal flasher relay.
